Hey guys,
I've searched but just wondering for this conversion:
What do I need to do to use the R34 ECU in my R32? I believe I have to get my R32 loom spliced with the R34 loom and use R34 afm/etc
Do I just get the looms spliced, put the motor in, plug the loom etc up to the R34 ecu and turn the key?
It's an Auto neo but I'm using my RB20DET gearbox. Will I need to trick the ECU into thinking it's in neutral/park?
What clutch should I use so as not to crunch my box (I know it will happen but I don't want it to happen too soon)?
Is it possible to get a 'replacement' flywheel? I'm not really interested in a lightened one and the RB25 has an auto flywheel on it.
Where do you get flywheel bolts from? Nissan Australia?
Thanks guys
https://www.sau.com.au/forums/topic/285675-rb25det-neo-into-r32-gtst/
The best thing to do is use the R34 loom and modify it to suit the R32. I normally remove the R32 specific wires (climate water temp sensor, wiper plug, fuel pump dropping resistor and body loom plug connectors) and integrate them into the RB25 loom. The only real issue you may encounter is using the AC. I can’t recall the detail but I noted it last I was reviewing the wiring diagram for the Neo.
If your car was originally an auto and you are converting it to manual you will need to bypass the inhibit switch but other than that I don’t recall any issue with the ECU.
With respect to your clutch you should be able to source one from your local wrecker, bolts as well.
The clutch you use will depend on your power requirements.
Hope this helps
  • 5 years later...
Hey guys
sorry to bring this up but i have just put a RB25det NEO into my R32 gtst,
everything mechanical is done, now I'm up to the wiring, i am using the NEO loom and ecu, basically the body wiring of the 32gtst into the NEO loom is what im wanting to do.
does anyone have a write up or guide for this ?
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
