RB25Det block $50. busted pistons. No sump or oil pump. VERY short motor.
RB25 R33 fan shroud $50
RB25 turbo exhaust housing $50. Modified for use with screamer pipe!
RB25 compressor elbow. $20
RB25 Det exhaust valves x 2. Brand new. $100??
3 x actuators. 14 psi. $50 each.
2 x bilstein rear shocks for VB-VL commodore. $50
1 x roll of 15% Professional window tint. Had this for years.. need it gone. Heaps on there. $80
GTR R34 stock turbo's. $650 pair. Great condition.
3L nissan Patrol / navara turbo. VERY low Km's. $200
TZR 250 (89) 2 stroke bike. $400 Bough for go-cart, never got there! 6 spd box..
CA 18 T25 turbine housing.. $10
Holset compressor wheel. Its BIGGER than my GT3040 wheel! $50
Turbo explanation toy! Teach your mates how these things work $10!
VL turbo cross over pipe $50
Sony head unit and 10 stacker.. hardly used (no idea even if it still works) brain cable and remote.. $10
Will happily freight to anywhere.
If you would like more info or photo's, pleaes ask.
open to offers on all things..
The Patrol turbo has a coloured past..
A guy owed me some money, I ended up with the turbo! :happy:
It was the only thing that lived through his engine blow up at (apparently) 15 000km.
Yep, spanking new engine off the shelf broke a piston in 3 bits (so the story goes).
So, as you can see, its VERY clean, shaft play is good, and it is a complete stock (unmodded) 3L diesel turbo as fitted to the 3L patrol. It has a variable Vane turbine housing. I removed to the housing to check it out, and it was also very clean and nothing broken or bent. I am only trying to recover some of the money I lost :) ..
it has a compressor cover A/R 0.53 and the rear A/R 0.64. The turbo has no oil or water fittings attached. Only the actuator for the Variabale vane.
If you wish to look it up, it numbers on the ID tag are:
FD 0402J
14411 - VC100
705954-15.
does that help?
More stuff in the shed!
Supra 2JZ-GTE turbo's.
$200 for both & all the bits in the photo's. Yes, the broken turbine wheel was me :D
Take one or both.. best offer.
Hey Aaron, I'm interested in go Kart engine can you confirm what engine, what condition any rebuid etc...
Cheers
David
  • 7 months later...
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
