  • 1 month later...
APEXI POWER FC no controller
Suits 200sx S14a
Returning car back to stock for sale at a later date
Safe tune on the computer with stock components on an SR20DET
Will Send at buyers expence
$850ONO
Thanks
May well be interested, drop me a PM. I would have done but I can't yet.
