My car has been running very hot for a while in between half and 3/4, i just recently got my radiator flushed and was told it was 85% blocked :flamed:
They also informed me at the time i needed a welsh plug replaced.
ANYWAY The car still seems to be running hot its not dropping any water now though.
Also how easy is to do a head gasket on a r32 could this be possible? i have checked and so far found no evidence.
https://www.sau.com.au/forums/topic/29104-im-worried/
i'd buy a second hand or reco'd radiator and get the welsh plug fixed...
you can warp the gasket.... but i dont think your car is getting hot enough to do that.... but act on it asap cause the longer you leave it the more damage that can happen later... and the more you "get used to it"
Happened to my dad.... he found out the hard way ....Boom!!!!
$$$$$$ later reco'd engine. Goes better now!! (it was a Jackaroo)
https://www.sau.com.au/forums/topic/29104-im-worried/#findComment-598057
yeah Pekatu thats normal
It should always stay at 1/2 no matter what. Any more and your in trouble!! I learnt this the hard way, i blew the head gasket on my last car and it cost me $$$
The stock gauge is fairly accurate, but an aftermarket one it will go up or down +/- a few degree's depending if you thrash it or just cruising...
Always keep coolent/water in your boot and if you ever see the guage go over 1/2 pull over before it gets too hot and see where a leak may be. Then top up your radiator and cruise your car to home/mechanics
https://www.sau.com.au/forums/topic/29104-im-worried/#findComment-598620
You might want to take a look at ur thermostat. In other words buy a new one cause there not expensive. They have a tendancy to jam half open wich will cause your car to run hot. If it was the head gasket you would be using heaps more fuel that u usually do and there would be a lot of black smoke out the exhaust from richness. Worth a thought.
Cheers
https://www.sau.com.au/forums/topic/29104-im-worried/#findComment-599018
How does a blown head gasket cause the car to use more fuel?
It will often allow water to get into the combustion chambers, giving white smoke out the exhaust, or may let oil in, with a bluer smoke out the exhaust.
Try the thermostat. If that doesnt work, do the waterpump, and make sure you bleed the system of air, there are bleed bolts (10mm head on my R31) on the intake plenum/manifold.
Good luck.
https://www.sau.com.au/forums/topic/29104-im-worried/#findComment-600072
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
