Here we have an S13 with a 5 speed manual turbo 1.8l engine. Engine was given a freshen up about 18 months ago with acl rings, bearings and mls headgasket. At the same time all seals, gaskets and clutch kit were done. It has a garrett t28bb turbo which blows no smoke with an intercooler kit and a 3in exhaust with a varex rear muffler. It has also had new radiator and heater hoses and a kit in the clutch slave and master cylinders. Engine has bosch coil conversion and is running 10psi boost there are also sports shockers fitted in the standard struts. Has 17inch speedy wheels with good tread and new brake pads. Inside has a full stereeo system, cruise control, climate control with ac that works, turbo timer, boost gauge. All electrics work fine and there is no rust around the sunroof, has tinted windows and a full alarm system with remote entry. The body has a few minor dents and scratches and the seats have come appart at the stitching but are still comfortable to sit in. Car is driven daily and is serviced every 5000km. Has not missed a beat in the 18months I have had the car on the road. Bought a new project so it has to go. Contact me for more info I am sure there are some small things I have missed. Asking $7500 and located in Murray Bridge SA. 0439379759.
Edited by bradr8
https://www.sau.com.au/forums/topic/294343-fs/
  • 3 weeks later...
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
