Nissan Cefiro
= $10,000 WITH the above parts and below mods
= $9,500 WITH the above parts, stock turbo not fitted and below mods
= $8,500 WITHOUT the above parts and with below mods
I have created 3 pricing levels for people to choose how they want the car. I will drop $500 off the price if someone wants
to take it without me having to fit the stock turbo and manifold because I am short on time.
The car has rego until Feb and still has an extensive list of mods. Would make a perfect streeter.
Here are the details, please contact me for more information on the car:
EXTERIOR:
CA31 Chassis - July 1989 Build
Manual conversion
M-Sports 30mm Flared & Vented Front Fenders - Genuine
Rear Guards Flared by 20mm
Full Respray in factory Diamond Black
Factory Sunroof
Late Model Tail Lights
Kaixon 6000k HID Headlight Kit
Legal Tint with Front Banner
ENGINE:
RB20DET
Stock turbo
Xtreme Chrome Moly 5.5kg Flywheel
Xtreme 9 Puck 25% Over Standard Clutch
SplitFire Coil Pack Kit
R32 GTR Coilpack Loom
No exhaust currently fitted.
East Bear GTR Cooler Kit & Piping
Custom Stainless Intake Cross Pipe (By C-red Tuning)
R33 GTR VSpec Intercooler (painted black)
Trust 10 Row Oil Cooler w/ Braided Lines & Spin on Adaptor (painted black)
Bosch O40 Fuel Pump with Source Power direct from Battery
New rocker cover gasket (2000ks old)
Nissan Steel Exhaust Header Gasket w/ new Nissan Studs and Brass Nuts
Quality Blue Silicon Used on all joins and bends
Silicon Vacuum Hoses
Silicon Radiator Hoses
Razor Grounding Kit
Oil Catch Can
Retuned Standard ECU - Socketed ROM (in Japan)
DRIVETRAIN:
2-Way Mechanical Diff (Nice and quiet)
Gearbox Had 6 Bearings Replaced (Synchros are crunchy which 'may' be caused by slave cylinders not opening fully)
R32 Half Shafts installed
HPI Braided Clutch Line
Brand New Speedo Cable
UNDERNEATH:
Tein HA Coilovers (Purchased brand new in 04, 35,000km old now with no leaks or clunks)
Tein Castor Rods
Castor Rod Mount Brace
Cusco Front Strut Brace
Adjustable Traction Rods in Rear
Adjustable Upper Arms in Rear
HICAS Lock Back
Drift Pineapples on Rear Cradle
Work Emotion Kai 17 x 9 +17 all round
Brand new Falken 452 on the front and brand new tires on rear (215's all round)
Full 5 Stud Conversion, R32 Rear & Custom Billet Front Hubs
New rotors and pads all round (2000 ks old)
20mm 5 Stud Bolt on Hub Centric Spacers on Front
Z32 4 Pot Brakes & R32 2 Pot Rears in Red (replaced Rear Brake Lines)
S14 Steering Rack & Custom Power Steering Lines
INTERIOR:
Sexual dash mat (extremely rare!)
HKS EVC3 Boost Controller
Greddy Boost Guage
Nardi Turino Steering Wheel
Standard drivers seat
Stock S13 (Passenger)
Razo Gearknob
Pioneer MP3 Head Unit
Pioneer 6" Splits
PICS:
Parts and car are located in Diamond Creek (NE Melb suburbs).
Contact me on 0412 033 449.
Thanks.
Edited by konect
Want to get this thing out the door sooooo
$8900
This is take it away as it is with everything included, with Work rims, oil cooler, Defi gauges, and all the above mods still on it!! Even has rego till Feb :)
Needs, stock turbo and manifold fitted and dump > catback
Was running perfectly before I pulled the old turbo off on the weekend.
Can deliver it to metro Melbourne suburbs on a tow truck :)
Edited by konect
swap for an ae86 with all 3sge and 6 speed, everything is done, just needs some tlc on the body and an engineers.
negatory my good man, just after cash :thumbsup:
  • 3 weeks later...
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
