Fs: R33 Series 2 Stock Dump, Front Pipe, Cheap R33 Front Guards, R33 Stock Springs, 235/45r17 Dunlop Sp Sport Tyres 60%
hey guys wanna get rid of this stuff. they came off a r33 series 2 and all in good working condition.
stock dump pipe r33 gtst: $30
stock front pipe r33 gtst: $40
Dunlop sp3000 sport tyres 235/45R17 with 60% tread left. Still very roadworthy without camber wear. took them off my wheels because they were too wide and scrubbing on my guards: $50
R33 guards that need abit of loving: $30 (follow the link bellow for pics and details)
http://www.skylinesaustralia.com/forums/R3...nt-t289847.html
R33 standard springs: $40
everything is located in western suburbs of melbourne and pick up only unless buyer is willing to pay for postage. thanks!
0432454387
Edited by jakez88
bumps
forgot to mention tyres are just a pair
Edited by jakez88
everything else is still for sale
Edited by jakez88
fi anyone wants both the stock dump and front, then its yours for $60! original sprigns are still available too.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
