Fs: R33 Series 2 Stock Dump, Front Pipe, Cheap R33 Front Guards, R33 Stock Springs, 235/45r17 Dunlop Sp Sport Tyres 60%
hey guys wanna get rid of this stuff. they came off a r33 series 2 and all in good working condition.
stock dump pipe r33 gtst: $30
stock front pipe r33 gtst: $40
Dunlop sp3000 sport tyres 235/45R17 with 60% tread left. Still very roadworthy without camber wear. took them off my wheels because they were too wide and scrubbing on my guards: $50
R33 guards that need abit of loving: $30 (follow the link bellow for pics and details)
http://www.skylinesaustralia.com/forums/R3...nt-t289847.html
R33 standard springs: $40
everything is located in western suburbs of melbourne and pick up only unless buyer is willing to pay for postage. thanks!
0432454387
Edited by jakez88
bumps
forgot to mention tyres are just a pair
Edited by jakez88
everything else is still for sale
Edited by jakez88
fi anyone wants both the stock dump and front, then its yours for $60! original sprigns are still available too.
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
