Selling my R33 Skyline Series 1 1993
(JETLNR)
Info:
- Auto (Fully rebuilt a month ago)
- 170,000k's
- Rego
- All standard option (Climate control, power steering, HICAS etc)
- Service every 5,000km with Penrite
Engine:
- Standard RB25
- 3540 low mount with .63 exhaust for minimal lag
- 3inch exhaust from turbo back with cannon muffler
- Custom dump pipe off the turbo
- Standard airbox and HKS Pod filter
- Turbosmart Boost controller
- HKS Front mount Intercooler
- Bosch 040 Fuel Pump
- 550 Injectors
- Haltech E6K wire in
- 280kw on 18psi
- Automatic counting Turbo Timer (Counts depending on turbo heat)
- Tuned by Ben D'annello
- Engine bay looks completely legal. Airbox is in the car and all sensors are hiiden e.g. map sensor and airtemp etc
Exterior:
- Custom Chameleon Paint job inside out
- It was sprayed about 3years ago. took off all badges including GT ones on the guard.
- Full body kit (Front has been customized to take out the number plate gap)
- Stealth rear wing
- Front Eye Lids
- 19inch Speedy Sphere Rims with 90% tread Machine Finish
- Lowered almost to the rims
- Tinted Windows
Interior:
- Custom Interior (Tan Leather with Black and Tan Door Trims, Centre console and Hand Break)
- Dash and other pieces in the car painted Chameleon
- 2 Gauges and shift light on steering wheel
- Aftermarket Shifter
- Fire Extinguisher (Painted in Chameleon)
- Pioneer 7' double din tv with 6 stacker inbuilt
- Pioneer 6' splits front and 6' rears (no holes)
- 2 12inch Subwoofers in the boot
- Cadence Mono block amp
- Sports steering wheel
This car is clean and body is extremely straight
Heaps more but best option is to come and see it for yourself
I'm asking around $17,000ono no reasonable offers or swaps refused.
Any other questions just call me on 0401 670 923 if no answer leave a message
Car is located in SE Melbourne
Here are some pics but i wil get some engine bay ones on soon but like I said best to see it in person
Edited by JETLNR
https://www.sau.com.au/forums/topic/300166-fs-r33-gtst-series-1-jetlnr/
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
