As new Samsung Omnia 8gb, Used only around 4 months
Still has plastic on the screen,
Comes with case for it and everything on the picture..
Its Vodafone phone but unlocked to use any network.
All Earphone and mic cable hasnt been open or used.
Prefer Pick up from Blacktown Sydney
Price $280
Postage $20
Msg Only on 0416 806 219
https://www.sau.com.au/forums/topic/300820-fssamsung-omnia-8gb/
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
    • My mechanic installed all the parts and then got it tuned which i think is around the corner from him
