1996 RS4 stagea series 1 MANUAL!
car is located in warwick qld bout 2hrs from brissy
my phone number is 0439665645 i would prefer sms's.... pm me or on write on this thread
more pics by request
Under the bonnet
  • Just had rebulid 3750kms ago (receipt to prove)
  • Always warmed up to operating temp before taken over 3,000 rpm
  • Always cooled down
  • running castrol edge oils last changed at the same times as plugs (250kms ago)
  • full 3inch mandrel bent system hiflow cat hotdog and cannon
  • just replaced the old gt35r(due to worn out bearings) new turbo has a .63 rear with polished housing
  • greddy style inlet plenum painted in marble
  • splitfire coilpacks with new plugs (replaced 250kms ago)
  • alloy cooler pipes with new silicon joiners and new clamps
  • 14' thermo fan (running off turbo timer)
  • new vaccum lines from the plenum
  • turbosmart dualstage boost controller
  • 600by300by75 cooler
  • brand new half size hi performance century battery
  • original stagea rs4 strut brace
  • greddy/trust style bov (currently not fitted)
  • haltech e11v2 - external 3bar map
  • tial external wastegate (with screamer)
  • himount stainless manifold
  • s15injectors... 480cc
  • 500hp walbro intank pump
  • drift catch can
  • gates blue radiator hoses
  • abs etc all the fancy stuff they came out with from factory
  • kn pod filter
  • haltech removes the afm and 02 sensor, but will go with the car including the original plenum and injectors
  • manual conversion with heavy clutch (unsure of what exactly)
  • sard pressure reg
Interior
  • jvc indash dvd player 7inch screen (double din) touch screen etc etc
  • 10inch roof mount screen with built in dvd player and av sockets with led interior lights
  • pioneer 6inch speakers in the 4 doors
  • soundstream trantula series 6.5 inch speakers in the tailgate(hatch)
  • 4 channel amp (running sub and 6.5s)
  • crossfire single 12inch sub in sealed box
  • new floor mats
  • stagea cargo mat and floor mat for tailshaft tunnel in the back
  • reclining rear seats (folding foward also)
  • electric front seats
  • interior is black leather
  • climate control
  • splitfire boost and voltmeter guages
  • superclean trim always kept tidy and maintained
  • powerinvertor also (plug in the playstation etc)
  • trust gearknob
  • factory tint in mint condition
  • pencil type turbo timer digital led
Suspension and exterior
  • bilstein front struts
  • kyb rear struts with kingsprings
  • 20inch daat d69 rims with removeable plastic insert(paintable etc)
  • brand new tyres (hardly driven on)
  • factory green metallic paint in vgc
  • also comes with 16inch 5spokes (factory type wheel) with unroadworthy tyres
  • Also i have rs4stg plate for nsw buyers if interested
since owning the car i have spent many thousand of dollars to get it where i am happy with it, altho there is still a few minor problems such as -
  • needs new exhaust manifold gasket (i have a brand new one ready to be put on)
  • a/c need gas
  • need new dump pipe flange (which i will be replacing as soon as i put the new manifold gasket on)
the stagea is currently running 14psi (no wear near its potential) so after the new dump pipe and gasket goes on i will be getting it tuned, the workshop beleives it will make approx 400hp at all 4s
Previously before the plenum, fuel system, and new turbo was fitted the stagea made 260kw at all 4s on 18psi... i have tryed to list everything but there could be some things i may have missed out on
i want $19,000 as it sits, which is only a fraction of what it owes/cost me and seems more than reasonable considering the price of other stageas i have seen... considering how good of condition it is in being manual and all the extras... i maybe able to remove parts to lower the price if required (such as rims, headunit, boost controller etc)
Im very open to swap offers looking at everything really just wanting a change, can also be view on boostcruising and will be on car sales shortly
Edited by lockie_003
https://www.sau.com.au/forums/topic/302067-manual-series-1-rs4-stagea/
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
