hey guys putting my 180sx up for eoi will sell at the right price or swap for an s14 or even an r32 with a rb25 but open to anything show me what you got
180sx 115000kms recod motor has only had 45000 according to dash in half cut however speedo was also not working hence not using it
body isnt to bad few minor dings no major damage or accident history previous owner thought nissan didnt do a good enough job of installing the door trims so he put a few self tappers through it... (thank god the stereo was the only thing he touched) i have removed them and fitted clips however holes are still there barely noticable dash has a hair line crack however still looks the part
2871 bb turbo
fmic
airfilter
na cams
full turboback exhaust
power fc with hand controller tunned
king springs
excedy heavy duty clutch
turbo timer
walbro fuel pump
schenider cd mp3 player + 4 speakers sounds great
has 17x9 rear 17x8 front sparco style rims will drop price if sold without wheels
made 194kw@10psi at bel garage
im sure theres more mods which i havent listed
the car has not been boosted past 10psi it has a very safe afr the way it is and more than enough power for simply getting around town and the fuel economy is amazing however with bigger inj and a retune you will see a sustantial increase
reason for sale my sr corolla will be comming out of the shop very soon and it has s13 front end so i wanted abit of a change from the s13 series
prefer swap however $8750
ono
beter pics will be up in the next few days
  • 3 weeks later...
swaps for r32 sedan?
basic mods
rb20
hks fmic
arc intake
kakimoto catback
hks bov
hicas locked
rays wheels 17x8/9
cusco rear coilovers
hks turbo timer
5" splits front
6" rear speakers
5% tints
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
