Hey guys.
The time has come where my ye ol faithful RB25DE S2 isnt going to cut it anymore.
Come with:
loom
ecu
harness
no flywheel
good compression accross all 6 cyl. (10% either way)
Heat wrapped coby extractors (could sell individually if someone is interested)
Engine has done about ~115,000km (exact km unknown)
Has had the 100,000km service done
Always regularly serviced with top shelf fluids.
Comes with a front diff sump. Can be changed to a RWD if you'd like to. (4.3 ratio)
Had this engine in my car for a little while now and it really is a decent little thing!
Loves to rev and never ever skipped a beat. Not even a missfire.
Would really be a good set up in something lightweight like an S13 or, rip the head off for a 25/30 engine.
$800 ONO
Located in Sydney NSW.
Best to call 0413208919 or PM.
Cheers,
Cris
Edited by GTS4WD
  • 2 months later...
Bump
Want this gone.
Taking offers
Best to contat 0403491735
SMS first is best as I have class most hours of the day.
Edited by GTS4WD
  • 4 weeks later...
  • 4 months later...
  • 7 months later...
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
