here is the updated list of all the parts i have left to save confusion only the parts listed below are still available for sale and prices have also been lowered again
used current model silver hks turbo timer with loom to plug into r32 and 33/s13/s14/s15? $100 with loom in near new condition
used japanese made nismo boost guage with digital exhaust temperature in the middle an awesome guage with the little controller box an older type of guage i know the boost works fine but not sure about the egt as i never ever drove the car to see if it worked correctly but i know it did work as far as i tested it if that makes sense $120
enkei RP01 wheels 17x9 22 offset all round no tyres wheels are 110% straight as i have had these all tested with centre caps a few scratches would be awesome awesome light as fck wheels with some paint currently silver $950 no tyres
riverside/zepter wheels 3 piece forged polished 17x9.5 17 offset NO GUTTER MARKS NO SCRATCHES PERFECT 4 brand new 255/40 tyres new valvestems all fitted and balanced ready to go all centrecaps and wheelnut cover plates (even have a few spares) $1990 very tough lightweight wheels
may seperate tyres and sell wheels if the right offer is made
used hks pod filters and cast alloy adaptors and brackets to suit gtr $130
brand new alpine cd/mp3 headunit with usb capability CDA-9884E $250
free postage included in the asking price for most small items
please check my older topic for pictures if youre interested or i can try and email you pics if you request via pm... postage is no problem on smaller items happy to package larger items if you want to organise the freight yourself
located in toowoomba qld 1 hr west of brissy, cheers :P
Edited by WHITE R32
  • Replies 57
pics please.
i have just found $700 bucks worth of receipts for some polish touch ups and repoilishing the caps and nuts and 2 new tyres valve stems fitting and balancing for the riverside wheels
tomek im working on your pics it seems my camera has a problem connecting to the pc at the moment... trying to get a new cable
Edited by WHITE R32
here are the pics i had on my pc... not great pics but u get the idea
if anyone is seriously interested once i sort my camera i can take more new pics of each wheel for you etc
below are the only parts i have left i have adjusted the prices on a few also
enkei RP01 wheels 17x9 22 offset all round no tyres wheels are 110% straight as i have had these all tested with centre caps a few scratches would be awesome awesome light as fck wheels with some paint currently silver $900 no tyres
riverside/zepter wheels 3 piece forged polished 17x9.5 17 offset NO GUTTER MARKS NO SCRATCHES PERFECT 4 brand new 255/40 tyres new valvestems all fitted and balanced ready to go all centrecaps and wheelnut cover plates (even have a few spares) $1890 very tough lightweight wheels
brand new alpine cd/mp3 headunit with usb capability CDA-9884E $240
ive tried finding that gauge for you but its in my spare parts gtr somewhere and its jammes up the side of the shed so i cant get the doors open...ill try and make my way in through the boot once i get a chance, sorry
on a gtst theyd sit roughly level with the guards and fill them right out for a tough stance... trial fitting is fine though
i havent had these fitted to my own car...
but use this tool to calculate where they will sit on your car http://www.1010tires.com/WheelOffsetCalculator.asp
we sat them on a s13 for fun one day and they were basically level with the guards with what was essentially factory camber dialed into it front and rear
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
