i have few parts that i would like to sell as i have no need for them any more
apexi power fc hand controller to suit evo or rx7 in very good condition $170 neg.
greedy cooler pipe. the one that comes straight off the turbo and hooks up to your air filters etc.
came off a t78 trust turbo but im pretty sure will fit any big single turbo conversion. $270 neg.
just jap oil cooler core. $100 firm.
i am aceptting offers but please no low ballers. pictures as above. do apoligise for the quality of the photos phone was playing up.. contact number 0423682131 loky :) located in campbellfield, victoria.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
