Hey guys,
Got this JVC Everio CamCorder GZ-MG330 today and really have no use for it so its going straight up for sale :action-smiley-069:
Its got 30G of space as i can see on the box and it says it takes up to 35hrs of video recording. Its also got a micro SD cart slot for extra space and 35x optical zoom and thats all the details i can see on the box atm.
It was purchased from a Dick Smith store somewhere and i called them up and they said they are selling for $500.
Asking price: $350 ONO
It hasnt been used and box is still sealed with a grey sticker that comes from factory as you can see in the image. Sticker looks a little pealed only due to handling.
Please PM me if your interested or with an offer.
Cheers
location please?
Sorry mate, Location is Hawthorn, Melbourne. But im more then happy to arrange postage at buyers cost or arrange meeting somewhere.
Cheers
  • 1 month later...
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
