Regarding checking everything,
The plan is to check my valve clearances and adjust at next service with my mechanic friend (NA_Goodness).
In my L24 tappet noise/click thread, MAG86 and Daewoo explain how to do valve clearances so i'm set with that.
Ignition Timing is all good, was checked approx 1 month ago.
Only thing i don't know about is cam timing, I'll see if my mechanic knows anything about it.
I'm going to with 25W-60 oil for next service to minimise blowby as well as topping up gearbox oil (suspect it's low).
and also which of the following should i use?
Engine Oil Flush Just before oil change. (I've heard the liqui moly equivalent is better, anyone agree?)
Long Term Engine Treatment With New Oil.
Worn Engine TreatmentWith New oil.
Lifter Free and Tune-Up With New Oil.
Manual Gearbox and Diff Treatment Add to existing oil in gearbox only not diff.
Will the bottom 3 work together without any problems?
after all that i plan to use Total Fuel System Cleaner to clean out the fuel system.
Other things include add oil to spare diff and swap in and new fuel filter.
I think I have covered all i want to do so far.
I've never bothered with any of the treatments you've listed. I'd choose a decent quality oil though for sure.
The cam timing is no biggie to check. Makes sense to do it at the same time as your tappets. Take of the timing cover and turn the engine over till piston 1 is at the top.
The big sprocket bolted onto the front of your cam can be bolted on in 3 different positions. Position 1 is for a new timing chain, position 3 for a stretched timing chain. The sprocket has a little notch cut out of it. When your number one piston is at top dead centre the notch on the sprocket will line up nicely with a little mark on the cam tower. If the chain has stretched the notch won't line up any more (I think the notch will be to the right of the timing mark from memory.)
If the notch and the timing mark don't line up you'll need too compensate for the chain stretch by unbolting the sprocket and repositioning it. If the sprocket is already on position 3 it's time for a new timing chain. Word of warning though, don't let the chain go slack at any stage, as there is a little spring loaded tensioner which will pop out of its home if you do.
The reason to bother with all of this headache is because your timing chain certainly will stretch as you start to clock up serious miles, and a floppy chain will definitely affect the performance of the car.
Good luck!
  • 3 weeks later...
Mech couldn't work out how to adjust the valve clearances, is it just one nut you undo and then move the rocker then tighten?
Service done as above but without long life engine treatment, no gearbox or diff work and used 20/60 penrite oil.
Pinion bearings are shot in my diff as well, i have spare diff to swap in (R180). On the half shaft bolts do i use a socket on the diff side and a ring spanner on the other? Tried with a mate with open ended and ring spanners and was slipping and wouldn't move. Should I spray WD40 on it beforehand?
thanks
Is your friend a Mech for a living?
Either he can't read a manual or doesn't know what an adjustible post with locknut looks like...pretty basic stuff.
Remove the rocker retaining springs
Rotate motor so heal of cam lobe is on the valve rocker arm
Undo the 17mm locknut and adjust the post with 14mm spanner.
Tighten locknut
RECHECK CLEARANCE
Refit spring (that way you know which are done)
I always loosened the locknut just enough to adjust the post because when you retighten the locknut the clearance can change.
I hope above is right (please feel free to correct people)as I haven't touched an L series in 30 years :-)
Edited by R34
He's an apprentice and hasn't worked on L series before.
The gregorys manual and L24 service manual I had on the day were very vague on the details.
I have since found the info i am looking for.
Thanks for help
Thanks for help
He's excused then :-)
Yeah Gregories are only good at street directories
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
