Make/Model: Nissan S14A
Year: 1996
Kilometers: 165,xxx
Transmission type: 5spd manual
Engine: SR20DET
Colour: Red
Modifications: See below
Roadworthy Certificate: N/A
Accident History: None.
Asking Price: $17k... open to sensible offers though.
Contact Details: PM, or call 0408961657 after 5pm.
Other Comments:
Regretful sale, but its time to move on.
The whole story for this car can be found here... with the slightly less in depth ns.com version here.
Bought it dead standard in late '08 with 151,000ish kms on it.
Since then, I've done all this;
Interior & Electronics;
Clarion DB286USB HeadUnit
Clarion SRG1620R 2 ways (parcel shelf)
Clarion SRQ1620S Components (doors)
NISMO Gearknob (+ dildo shifter for shits and giggles)
JDM S2 stereo, climate, and gear surrounds.
VELO GP90 Drivers Seat on modified Bride rail
STRI White Face Gauges for; Boost.
Shadow White Face Gauges for; oil temp, oil pressure.
PIVOT Water temp gauge
Bosch 6000K HID kit and arctic white parkers
Extended + battery cables
SuperCharge Slim battery
35% Tint
Engine/Intake/Exhaust/Cooling;
Standard turbo rebuilt and highflowed to 2860 specs
Genuine Nissan coolant
K&N Oil Filter
HKS Alloy suction kit
Elf Excellium 5w/50 fully synthetic
NGK BCPR6ES plugs (.8mm gap)
Modified Airbox w/ cold air duct + K&N element
M/Steel 3" Apex'i Catback exhaust
AM Performance S/Steel Dump & Front (with seperated wastegate flow)
X-Force Catalytic Converter
Brand new Genuine Nissan Gaskets for; Mani -> Turbo, Turbo -> Dump, Cat
Brand new Genuine Nissan turbo studs
Brand new Genuine Nissan Water lines
Braided Steel oil line
Deleted BOV
Cooling Pro FMIC w/ custom brackets
Custom S/Steel 2.5" intercooler piping
Turbotech MBC (hybrid ebc wired in, needs tune)
Earls oil cooler and relo kit with speedflow fittings
R33 GTR fuel pump
Nismo Mounts
KTS Engine Torque Damper
Driveline;
Standard 5 spd Box
Xtreme Heavy Duty Organic Clutch
Nismo Mount
Standard Nissan "LSD"
Wheels & Tyres;
Front;
Enkei Circlar 17 x 8 +35 Resprayed in ROH silver
Work Mesh 17 x 8 +5
Work Equip, 17 x 9 +17 (estimate)
225/45 Kumho KU36
Rear;
Enkei Circlar 17 x 9 +38 Resprayed in ROH silver
Work Mesh 17 x 9 +11
235/45 Dunlop Direzza DZ101
Brakes;
Front;
RDA Slotted Rotors w/ ACRE Street pads
HEL Braided lines
Rear;
RDA Slotted Rotors w/ QFM HPX pads
HEL Braided lines
Fluid;
Penrite syn 600
Suspension & Steering;
Cusco Zero 2 R Coilovers
Cusco Front strut brace
Cusco Camber Arms
KTS Tie rod ends
Kazama castor rods
Body;
JDM Kouki wing
JDM front bumper w/ foglights
Navan Zenki side skirts
Navan Zenki rear pods
Rolled guards
Domokun chilling the rear quarter glass.
Performance;
136rwkw @ Graham West Workshop (Catback exhaust, exhaust leak at turbo, missfire, 11psi, 14/3/09)
171rwkw @ Morpowa (dirty and untuned, 2860, full exhaust, cooler, standard pump, 14psi, somewhat naffed pump)
170rwkw @ Morpowa, same as above, but with gtr pump and mega rich mixtures.
PB of 1:27:00 @ Mallala.
On top of all that, its getting a brand new pair of kumho KU36's on the front in the coming days (rrp $560), the old KU36's will be moved to the rear.
There's a new set of A1RM rear pads coming ($119).
And I'll throw in a set of blitz 550cc injectors, an ATS carbon single plate clutch (that needs a rebuild), and if wanted, i may be able to arrange a Z32 afm with plug for an additional $200.
I'll also be including, 4 stockies, 2 with legal tread, 2 without, standard dump and front pipe, standard drivers seat, standard struts/arms/rod ends, standard front bar, standard intecooler/pipe work/bov, standard boost solenoid, spare rear garnish, spare bootlid w/out spoiler (does have holes).
I'm happy to remove parts to make it more affordable.
I am however, in no rush to sell it, keep that in mind.
Now for the nitty gritty, yes, it has been tracked (3 times), and yes, it has been driven hard, there no point hiding that.
However, its been religiously maintained, I don't stick to a service schedule so much as service it whenever I believe it's appropriate... or have nothing better to do. As such, it's been serviced with quality oils (at first, motul, more recently; elf excellium) and filters (nissan, and more recently k&n) every couple thousand kays (about 9 times since purchase). It's most recent service was 2 weeks ago, changed oil, filter, plugs, fuel filter, and fitted a brand new k&n air filter. I'll be servicing it again in the coming days.
A compression test was performed mid last year for peace of mind, came back with 141-145 across the board, a leak down test was performed at the same time and returned results within factory tolerances.
A suspension safety checked was performed recently, with everything showing up apples, but, the steering rack bushes are starting to show wear.
And its passed regency with minimal work, standard wheels, borrowed standard exhaust (or baffle plate), standard boost controller, removed gauges, standard seat, and it's through without incident.
Now for the bad. there are a couple small chips in the paint, and some poorly repaired parking lot damage to the rear drivers side guard. I'll get pics of all this up later... and that's about it.
Basically, as it is, it's an lsd and a remap away from being whatever you want, drift car, grip car, hills car, or just leave it as is and have a bullshit tough streeter, it's up to you.
Edited by scandyflick
https://www.sau.com.au/forums/topic/317477-96-s14a/
just realised, ive basically copypasta'd this from a build thread and some of the coding didnt come along with it.
so i should probably point out that only the work equips and stockies are included in the sale, the other 2 sets have been sold.
https://www.sau.com.au/forums/topic/317477-96-s14a/#findComment-5193429
bump.
new tyres will be fitted up today. and im chasing up another set of new rear brake pads as im getting sick of waiting for my qfm's to rock up.
https://www.sau.com.au/forums/topic/317477-96-s14a/#findComment-5197313
  • 3 weeks later...
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
