hi guy's,
im putting my cressy up for grab's because another car has come up that i want to jump on...
its been a good car and rarly get's driven" i have gf's car as a daily"
rego: FEB 2011
314,000km's on chassis
approx 150,000 on engine.
engine:
full jzx81 motor with new toyota front sump fitted
2jz waterpump and housing been done"has to be done to run without the gay viscious"
steel wheel ct12 turbo's fitted "running 12psi"
various heatsheild's etc have been ceramic coated
custom dump pipe's into twin cat's and twin muffler's
front mount with custom pipe work to suit
boost/fuel cut defendor installed
larger intake fuel pump
trans/driveline and suspension:
a340e tran's with mv automatic's stage 1 kit
newish bilstien shock's with custom spring's "sitting approx 1inch lower then std"
whiteline custom front and rear sway bar's
grande lsd with custom strengthend rear subframe and larger diamter diff mount bush's installed
jzx81 steering rack fitted "more lock"
jzx81 crossmember and associated suspension
jzx81 strut tower to firewall strut brace.
brake's/wheel's:
ba ford front rotor's with nissan 4 piston caliper's
slotted rear's
bendix pad's all-round
all caliper's rebuilt
17" is200 wheel's with near new front tyre's
interior
immac beside's c-pillar trim's
newish sterio fitted "i-pod/usb aswell as bluetooth headunit"
cold air con! however the heater literaly just stopped working "2 day's ago"
aftermarket tempreture gauge fitted "std not wired up"
speedo has been recalibrated aswell as the tachometer
outside the car is also good however there is a few mark's etc on it
bootlid is faded etc
tow bar fitted
serviced literaly once a month as i get oil's for free
timming belt/water pump,spark plug's and its also running twin fuel filter's
radiator reccently reco'ed and toyota red longlife coolant added
previous owner has taken it to wsid and did a 13.0
most importantly ZERO police attention! we all know how valuable this is these days.
HOWEVER the car is engineerd incase you should be hassled
under the bonnet is stdish looking "comodore airbox etc"
perfect daily with abit of poke!
located in hornsby
$8000 neg
i am open to trade's however prefure cash as i have a car in my mind
i am also willing to neg for a REASONABLE amount..
prefure contact via pm
https://www.sau.com.au/forums/topic/320904-1jz-powerd-mx83-cressida/
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
    • Yeah so physically that port is consult not OBD2, but also be aware that "JODB" is not really a thing - it came in around 2000(ish) but is not a standard like ODB is, each manufacturer had differences. If you are looking at ECU only and have a standard ECU, go with Datascan as Turbo Tapin said. Per another recent discussion here thought that won't do other systems like in a modern car, for example bleeding ABS
