hey guys, been living here for a few months and working as a tyre fitter.
but currently looking for something less physical. trying to get out of the labouring side of things.
if any one has some first hand knowledge of were to start looking eg. office jobs or retail let me know
any help would be awesome. backs starting to not cope
https://www.sau.com.au/forums/topic/321328-job-hunting/
Launceston is a bit far away. I'm living in glenorchy at the moment.
At the moment I have very limited skills which would be suitable for an office job. I'm just looking to get out of the labouri g side of things. I have good computer knowledge but am willing to learn or take courses necessary.
https://www.sau.com.au/forums/topic/321328-job-hunting/#findComment-5246812
  • 2 months later...
  • 3 weeks later...
It might help mate, if you posted up what you can do.
Can you use Microsoft office?
Can you use any work related programs or have you used them before? MYOB? any tax programs and so on? It might be an idea to get your hands on some of these and have a play around. If you can familiarise yourself with them, you would be a bit more "skilled" for an office job.
But IMO most office jobs consits of answering phones, transfering calls,
collecting mail, filing, organising paperwork for people,
and general computer work (depending on the industry).
this is obviously a *very* generalised and simplistic synopsis of what it is to do an office job. there is more to it... but generally they would be your main tasks
https://www.sau.com.au/forums/topic/321328-job-hunting/#findComment-5442095
Do the rounds at the department stores as they've all started hiring for Xmas but u may be a bit late.  Just another bit of advice, dress as u would for an interview and be polite to any of the staff you may speak to.  They usually write on the top of the applications their first impressions as you probably won't be speaking to the manager and be available to work.  I have put many applications aside cos applicants have dictated to me when they wanted to work.  if ur looking for 9-5 Monday to Friday then forget working in retail or hospitality.
https://www.sau.com.au/forums/topic/321328-job-hunting/#findComment-5444549
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
