Item Summary: 18" AME PRIDORS little dish, 4 x 100, 4 x 114.3
Condition: Used, but great, no gutter rash etc
Reason for Selling: no use
Delivery Methods: PickUp
Contact Info: email, phone
Extra Information:
Hey guys i have up for grabs a full set of 4, 18" chrome genuine AME pridor rims
PCD 4-stud multi:
- 4 x 100
- 4 x 114.3
suit r33 gts, r32 gts, s13, s14 not sure of others
rims are in almost perfect condition and come with great rubber
Price $700.00ono
Contact: [email protected] (email & msn), 0419761510 (text), PM or reply here!!
Cheers Hame
this pic is off a website..will get more soon!!
Edited by H@ME
https://www.sau.com.au/forums/topic/322393-18-ame-pridors/
still here, these rims are in mint condition for 2nd hand rims, comes with good tyres..
will consider swap for set of 5-stud rims suit r32 gts-t, but prefer cash offer
hame
https://www.sau.com.au/forums/topic/322393-18-ame-pridors/#findComment-5264239
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
