Hi guys and girls,
I have a complete set of *BRAND NEW* DBA Street Series Slotted Rotors.
DBA908SR, DBA908SL, DBA909SR, DBA909SL.
To suit Nissan Skyline R32 GTS-T front and rear.
No longer have my skyline now and my ceffie has GTR brakes all round so don't need them. Fronts were trial fitted when I bought them are still brand new never been driven on, and Rears have never been out of the box.
RRP on these: Fronts $209ea and Rears $179ea
Asking price $550 for the set - am willing to separate if you are only chasing a pair. Will work out a price accordingly.
Located on Sunshine Coast QLD, is possible to organise freight at buyers expense.
PM me or post on topic
Cheers
Kails
no
well i just checked the dba website and they are saying that r32 gts-t rear and r33 gts-t rear are the same.
they are the same size rotor and same size thickness.
ta,
kails
Just to let you know to increase your market to sell too the dba 909 also fit the front of s14/s15 200sx, front of 300zx z32, silvia s15 turbo as well as the r32 gtst, the dba 908 fit rear of r32 gtst and gtr up to 8/93,rear of r33 gtst, rear of r34 gt and gtt, rear of 300zx z32,
thanks heaps :D i only knew the rear also fitted r33 gtst so there you go thanks for the helping hand
  • 1 month later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
