R33 Syd - Carbon Fibre Bonnet, Rear Bootlid, S2 Wing, Floor Mats - Other Random Bits. All Goin Cheap!
Just sold the car last week. Randoms parts for sale. Going cheap! located Randwick NSW
All prices FIRM.
Carbon Fibre Bonnet, (laid over fibre glass, Unknown origin), sold as per picture. Exo skeleton still underneath for legality. removed trim piece - $340
Rear Bootlid (black) - $40
S2 Wing (black) - $15
Skyline Floor Mats (5 pieces) - $60
Rear Vision Mirror - $5
A/c vent (centre) - $5
Sunroof glass (some rust) with other sunroof bits - $30
0406 370 292
Please SMS for quick response as hardly check site these days.
Edited by Lost
ADDED SOME OTHER ITEMS> READ THIS VERSION ...
Carbon Fibre Bonnet, (Laid over fibre glass?, Unknown origin), sold as per picture. Exo skeleton still underneath for legality. Removed trim piece. Looks tough on car. Makes car look lower as the bonnet is flatter - $340
Rear Bootlid (black). No lock. - $40
S2 Wing (black). Good condition. Resprayed in 2Pak but has some scratches from storage - $15
Sunroof glass (some rust) with other sunroof bits (lights, switch plus lining) - $30
Super rare Dash Mat. Great condition - $30
Custom Catch Can. Hand made with internal baffles. Pirtek fittings. Monza Breather - $50
hey mate, can you save the rear boot for me... ill be more then happy to buy it on the weekend... sunday?
already txted him the other day, im takin it :)
Status Update
Floor Mats - SOLD
Dash Mats - SOLD
Bonnet - Deposit Taken
Bootlid - Almost Sold
Everything Else still Avail!!
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
