ok guys i need abit of help mainly places to start looking with my laurel which was having a few issues on Saturday at a drift day,
Car: nissan Laurel
Motor: series 2 RB25, ignitor on coil type
Mods: greddy copy plenum, tr43 turbo, split fire coils, AFM in cold pipe before throttle, extended wiring over engine bay , XF falcon throttle with tps sensor, mostly stripped wiring loom, Power FC computer
Problem, started off the when i'd throw the car in for a scando it would cut out for a second or so then accelerate again, thought it was the
fuel pump as it was very noisy (not a usual loud hum, sorta a gurgling type sound) so changed that out with brand new 040 and went back out on the track. car ran for about 6 or so laps fine then it started to cut out again but this time i would only have to start accelerating (putting load onto the engine about 3/4 throttle type thing). the cut out was like the car turned off, it didn't cough or splutter blow smoke or any of the usual suspects for like a blown cooler pipe or vacuum line. and the only length of silicon joiner is the 2inch 90degree bend coming off the turbo everywhere else is steel piping, bends etc and just short joiners. metal induction pipe and air filter a one of the drift type solid shape
So now i'm confused, first thought after the fuel pump was the ignitor but as these are on the coils on this motor it wouldn't cut out like it is i would have thought, next would be afm but before i start going over everything i just wanted to check if there may be another problem i could be overlooking.
any help would be appreciated, i've never had an issue like this before so i'm stuck
Im pretty sure similar thing happened to me on the weekend at the track. After a few runs suddenly sometimes as I downshifted to gear 2 and pumped it out of the corner its like the car just stopped and didnt do anything then let off the acclerator and pumped it again and it went, not sure what it was but yeah changed to spark plugs just for the sake of it hasnt done it again but then again it only did it a few times.
I was thinking aswel it could be a fuel pump issue but Ive got a nismo fuel pump so the mounting and all that shouldnt be an issue since its direct drop in and I had plenty of petrol, and it sort is like a missfire cuase it just stops the car and it like its stuck but yeah my plugs were pretty old so I guess it would be the cheapest thing to check first.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
