Hey All,
I've got an R33 RB25DE+T (Stock RB25DET ECU and Injectors), with an AFC Neo piggy back and a wideband O2 Air/Fuel ratio + RPM datalogger (innovate).
I've had the car on the dyno before so i knew the fuel mixtures were way out, on my first run everything was spot on, the AFR's at RPM points match the dyno plot perfectly.
At light throttle with my cars lambda sensor disconnected the car ran at 10:1 AFR, which was fine - I was able to lean this to the 12's no issues whatsoever (took -20% on the AFC), this was my practice and everything was fine. So now I started to work on my massive lean spot at WOT (car lean spikes to 16:1 at 3000rpm), kept adding fuel up to +50% but it didn’t make any difference... Moving on from this I tried to adjust my rich spot up top (10:1 AFR from 5000 to 7000rpm) no matter how much fuel i pulled out of it, it just didn’t make any difference to fuel mixtures or the pull of the car. The AFC shows the correction (in the monitor mode), but it just doesn’t do anything... It's like the ecu is RPM mapped at those points... The more i lowered the boost (its at 10psi), the better the lean spike looked (~ 8psi brought it to 14:1).
Any ideas? The AFM in and out are both set to 1 is this correct? All wiring is perfect.
Cheers for any info, don’t tell me to take it to a tuner.
https://www.sau.com.au/forums/topic/327734-apexi-afc-neo-safc-tuning-issues/
I think I've found the issue (though not sure if it would cause my symptoms...?); I installed this based off this guide:
http://www.skylinesaustralia.com/forums/Sa...3-G-t85232.html
Where is says set AFM IN and AFM OUT both to 1
But reading here: (Page 24)
http://www.scribd.com/doc/19576441/Apexi-I...-Wiring-Diagram
It says set both to 4.
I'm not sure if the AFC is different, or if it is wrong, or even if it will make any difference - I'll have to wait until I get home tonight.
Please still post if you have any other insights...
Have you made sure you've set your throttle position as you have to calibrate it for your car? As it sounds like the % for the hi map is screwed up. Should be around 35% that it switches
But yes iir it should be set at 4 both in and out.
Edited by jjskyline79
Yeah that’s set right, low throttle comes in at 0% and high throttle is at 40%.
I've tried moving the threshold higher to run of low throttle maps, but it doesn’t make a difference. Regardless it runs increasingly rich until around 45% throttle, then it leans right out.
Setting it to 4 & 4 didn’t make a difference. I randomly set one to 1 and one to 4 to test it and the car spluttered like expected, so it is working...
Here's a picture of my wideband log, RPM vs AFR, you can see the lean spot which i am trying to iron out....
I really hope not, can’t really fork out for full management. Everything is fine I just need to correct these fuel mixtures.
There must be a reason for this issue... Its not like I can’t adjust it any further, its simply just not making any difference to mixtures (even if I +50% it).
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 🤣, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
