hey all, im new to this site & skylines
i recently bought a R33 GTS4 paid about 3500 for it.
i was just wondering is there a way to disable the attesa system?
and then simply just plug it in again?
or is this only the R32's?
any feedback would be greatly appreciated:)
thanks
https://www.sau.com.au/forums/topic/329610-gts-4/
you cannot just pull out a fuse like in the 32's. this is because their system was electrical and the 33's are hydrological.
You can drain the resovior in the boot but the safest thing to do is take out the front drive shaft.
BTW, how did you manage a 33 gts4 for 3.5k? is it damaged?
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5356095
The caniser in the boot runs down to the actuator on the O\S\R of the car, it pumps fluids to the transfer case and when the slip light is activated it then runs too the rear diff and is pumped around there aswell, then back too the canister. It does this because it is a high pressured pump that activates clutch packs in the transfer case, this is how the attesa system works. Do not take the fluid out of the clutch packs with be distroid and you will have to spend a lot of money and all the parts with be EX jap.
The fluid is a ATF fluid, at nissan we sell nissan Matic D which is what they used stock.
You can take the front propeller shaft out but thats it.
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5357381
how would i pull out the shafts? just pull them out
your only taking out the front shaft.
It is located under the car more towards the drivers side next to the gear box area.
there are four bolts that attach it to the car, they are in pricks of a position to get off...
the thing i do is, move one bolt at a time to the best position possible for you to reach by rolling the car, undo it and take it off, roll your car a little back or forward so the next bolt is in the same position and repeat.
when you get good at it, you can have it off in 10-15 mins if that....
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5357421
As said before.
You can only disconnect the 4wd system in the R32's electronically.
In the 33 and 34 you must remove the front drive shaft.
This is the shaft from your transferbox (the thing hanging off the drivers side of the gearbox) going up to the front diff.
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5359314
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
