hey all, im new to this site & skylines
i recently bought a R33 GTS4 paid about 3500 for it.
i was just wondering is there a way to disable the attesa system?
and then simply just plug it in again?
or is this only the R32's?
any feedback would be greatly appreciated:)
thanks
https://www.sau.com.au/forums/topic/329610-gts-4/
you cannot just pull out a fuse like in the 32's. this is because their system was electrical and the 33's are hydrological.
You can drain the resovior in the boot but the safest thing to do is take out the front drive shaft.
BTW, how did you manage a 33 gts4 for 3.5k? is it damaged?
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5356095
The caniser in the boot runs down to the actuator on the O\S\R of the car, it pumps fluids to the transfer case and when the slip light is activated it then runs too the rear diff and is pumped around there aswell, then back too the canister. It does this because it is a high pressured pump that activates clutch packs in the transfer case, this is how the attesa system works. Do not take the fluid out of the clutch packs with be distroid and you will have to spend a lot of money and all the parts with be EX jap.
The fluid is a ATF fluid, at nissan we sell nissan Matic D which is what they used stock.
You can take the front propeller shaft out but thats it.
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5357381
how would i pull out the shafts? just pull them out
your only taking out the front shaft.
It is located under the car more towards the drivers side next to the gear box area.
there are four bolts that attach it to the car, they are in pricks of a position to get off...
the thing i do is, move one bolt at a time to the best position possible for you to reach by rolling the car, undo it and take it off, roll your car a little back or forward so the next bolt is in the same position and repeat.
when you get good at it, you can have it off in 10-15 mins if that....
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5357421
As said before.
You can only disconnect the 4wd system in the R32's electronically.
In the 33 and 34 you must remove the front drive shaft.
This is the shaft from your transferbox (the thing hanging off the drivers side of the gearbox) going up to the front diff.
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5359314
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
