  • Replies 77
r33 complete wiring harness $80 for s1 or s2?
also still have the catch can for sale?
PM BACK MATE
hey bro series 1 complete wiring harness and i do have the catch can
yep the steering wheel plastic cover.ill grab the boot interior aswell.
your not from brisbane right?
nah bro not from brisie and i have the steering wheel plastic and boot interior still
hey bro, with the drivers door does it come with the window and power unit to open and close it? If so how much and how much for the tail lights?
yea man the door comes with everythink glass motor switches wiring for $100 and the tail ligths $100 plus postage
hey bro, how much to get it shipped to sydney? And can i only get the door trim with the buttons and the window motor for $60, i thought the door was silver not black. Also still want the tail lights regardless of weather i get the door stuff or not so put them aside.
hey man jsut wanna sell it all as is man sorry
Ok then well can you find out how much it would be to get it sent to sydney, i'd really like the tail lights just by themselves! PM me your details and i'll call you about mine.
$32 postage man
my bank details are brenton n neill
a/n 1015 6821
bsb 064210
so $232
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
