Hey up for sale is my 1997 Toyota chaser tourer v factory manual (jzx100) it has a 2.5L vvt-i turbo engine with tasteful mods(120,000km). . Im asking $19,900 o.n.o
If youre looking for a neat, quick, reliable and smooth car then this is for you, had no problems at all With it runs great and looks great recently had the 100xxx major service done and new tyres on rear along with new brake pads all round and machined rotors so save some money its my loss and your gain. Car will not disappoint!
Extras:
. High flowed CT26 turbo (done at a.t.s 10,000km ago) (runs stock boost)
. Exedy HD clutch (done 10,000km ago)
. Front mount intercooler
. Tien flex fully adjustable coilovers
. All oils changed (1500km ago) (engine oil done every 4,000km)
. Custom dump pipe with 3" apexi exhaust system and cannon
. Speedy hp design wheels 18" by 7.5 wide with new tread
. Black tint, trd shifter
. Kenwood touch screed dvd/cd player with jbl sub and 4 6" speakers and 2 tweeters.
. Comes Factory with:
. torsion lsd diff
. Xenon lights
.Powermirrors
.Carboninserts
. Very clean interior and seats
.Xenon lights
.ABS
.4 airbags (2 side, 2 front)
All up its a nice car to drive and in mint condition, first to see will buy, please no time wasters feel free to ask me anything just txt or call me anytime on 0433440530
thanks.
https://www.sau.com.au/forums/topic/334280-jzx100-chaser/
im not to sure man the owner before me did it all, correct me if im wrong but iv been told its a ct15 bored out/machined out to a 26 and put a steel exhaust wheel instead of ceramic.
So you put a hi-flowed ct26 on it? What are the specs and why not hiflow the ct15?
https://www.sau.com.au/forums/topic/334280-jzx100-chaser/#findComment-5417793
its possible. wouldnt know without looking at it. if you can, grab a photo of the turbo inlet. If its hi-flowed it 'should' be machined out and can tell from photo
If it's hi flowed it does indeed use ct26 internals but looks just the same as a stock one.. I'm about to do the same on my chaser, it's good to keep is looking stock
https://www.sau.com.au/forums/topic/334280-jzx100-chaser/#findComment-5427067
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
