hey guy's got my sr FS
*Arias 40 thou over size forged pistons
*Arias Chrome moly rings
*Scat H-beam rods
*ACL race bearings (main and rods)
*ACL race bearings (thrust)
*Full genuine Nissan gasket set
*HKS multy layer metal head gasket 1.6mm
*HKS heavy duty valve springs
*HKS Camshafts step 3, 264 EX and 272 IN
*HKS adjustable cam gear inlet and exhaust
*Tomei solid lifters
*Tomei rocker stoppers
*Brand new Nissan rocker arms
*ARP mains
*ARP headstuds
*Trust TD06-25G 10cm turbo with polished front comp cover, fully rebuilt and balanced by ATS
*Custom high mount steam pipe manifold
*HKS external gate 48mm with screamer pipe
*Sard 850cc injectors and plugs
*Greddy inlet plenum
*Xtreme custom made GTR clutch to suit SR20 1600kgs solid centre with Moly flywheel
*RB25DET gearbox with custom bellhousing
*Head was faced, valve stems seals, acid dipped
*Block has been bored, faced, tunnel bored, crack tested, honed, acid dipped, crankshaft crack tested, timing chain cover machined to suit both all done by Chris Milton Engine Developments.
Any questions just ask thanks dave
im after 15,000
Edited by ddm_s15
https://www.sau.com.au/forums/topic/334893-330kw-sr20-fs/
bump need to sell
mob number 0408218945
would help your sale if you could give better info like when it was built, how old parts are located ect, just my 2 cents worth
https://www.sau.com.au/forums/topic/334893-330kw-sr20-fs/#findComment-5425804
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
