Due to time wasters this is back up for sale again.
HKS EVC III Boost Controller
In very good condition, only negative is that it has a little double sided tape still stuck to the underside of the unit.
Was working perfectly in my S14 but is no longer required and I could better spend money elsewhere at the moment.
Chasing $250ono delivered express post anywhere in Australia.
Located in Brisbane, QLD and pickup is also available.
0420 856 464 or PM me.
Cheers
Jamie
https://www.sau.com.au/forums/topic/334952-hks-evc-iii-boost-controller/
