Practically brand new Cagiva Mito 125 in matte black.
I have all the manuals for it and comes with RWC.
Stock items include Brembo brakes as well as Mazzoni shocks.
Chasing $5,500 ONO.
Will swap for car with cash your way, but let me know what you've got.
Thanks for looking, PM me for details
https://www.sau.com.au/forums/topic/337451-cagiva-mito-125/
Bump
Please note it's still registered and has RWC. Good to go for a good owner.
Am willing to accept a trade for a car and cash adjustment your way if necessary.
https://www.sau.com.au/forums/topic/337451-cagiva-mito-125/#findComment-5463676
Keep the PM's rolling in.
This is a 2008 (final) model. Perfect for a learner who wants the looks to go with the performance.
4 out of 5 stars on MCN magazine.
Full tank of V Power is on $10 and lasts roughly 280km's.
https://www.sau.com.au/forums/topic/337451-cagiva-mito-125/#findComment-5518884
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
