Hi Guys,
As above, I have R34 GT-R seats I'm wanting to put into my R34 GTT. The rails are obviously totally different, so I was after someone who may be able to assist with the modification of the rails to suit the GTT floorpan.
Cheers,
Dallas.
Edited by OKBANANA
https://www.sau.com.au/forums/topic/339889-seat-rail-fabrication/
The R34 GTR and GTT had totally different floor desings sadly. It's just the tabs on the rails that need to be modified to suit really.
i know but what i said is i have 32gtr seats in my gtt... how similar 32gtr and 34gtr seat rails i dont know if u can find that out i could help u
