As title says used turbosmart eboost 2 for sale.
I bought from a friend several months ago and now no longer need it.
Autobarn sells them for 795$
I'm after 550$ Ono..
Located Adelaide hills.
0419837474. SMS/phonecall preferer rather then pm
thanks
https://www.sau.com.au/forums/topic/340281-fs-turbosmart-eboost-2/
  • 3 weeks later...
this is second hand
was installed on another car and taken off- no longer going to use it as i intend on using the nistune boost solenoid setup instead.
open to offers.
hey there
is it new or 2nd hand?
thanks
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
