HI guys just purchased a R32 skyline gts-t and im looking for either a new dash or odometer. Reason being my spedomoter stopped ticking due to the rod not being spun.
pm me or contact me on 0423 013580
Also after a drive shaft
thanks guys
Edited by KinG_KonG
https://www.sau.com.au/forums/topic/341837-need-a-new-odometer/
You sure its odometer???
The little square pin in the speedo cable can sometimes dislodge (break) & spin freely which is a common fault with R32's or many mechanical speedo cable for that matter...
I have had the same problem im the past, replaced speedo cable and sorted...
Hope that helps
Hope that helps
Where would i get the speedo cable from. I rotated the square pin manually and the revs increased so its not the speedo yeah??? how would you suggest i fix this?
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
