Was fitted to my 87 300ZX originally, however the boss kit was designed for an S13.
As i have purchased a R32 GTR it had already came with a decent wheel and boss, Didnt see the need to swap this wheel across.
Used for 2 > 3 months max, Comes with a boss kit valued at $99. Originally purchased for $299.
Yours for $250 for the wheel and boss kit.
I dont have any current pics of the wheel however is essentially new and looks exactly like the following:
Contact me either via PM or 0411665826 if you would like to take a look.
https://www.sau.com.au/forums/topic/346118-momo-prototipo-w-boss/
Mmmm honestly not sure, i could pop it onto mine and test fit perhaps.
I'll see how much spare time i have, I probably wont get the chance until the weekend though.
Though if i do that i may be tempted to keep the wheel on my GTR xD
Edited by ZED X
No worries mate.
ZILLR: I attempted to get the Boss kit off my 300ZX, however the bugger is held on there quite well. I'll take another crack at it on the weekend with a wheel puller and see if it fits on the GTR.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
