Sawers_88 Posted December 1, 2010 Share Posted December 1, 2010 Ok first up- Spec's for the altessa fluid? sitting on the low mark atm wondering what fluid to actaully top it up with. using gen nissan fluids so is it a matic d or matic j fluid? or is it just a general ATF fluid? Next up- Has anyone had any experience with tunning/dyno'ing rs4's? just after general bit of info on tunning places in adelaide. Decent places to go with 4wd dynos. Also are stagea ecus remappable? Link to comment https://www.sau.com.au/forums/topic/346166-info-c34-after-tunning-infosouth-aus-and-altessa-fluid-info-ect/ Share on other sites More sharing options...
chef_stagea Posted December 1, 2010 Share Posted December 1, 2010 mate give turbo tune a call south rd... tell them what u want and off u go.. as for atessa fluid... get some transmax z from your local repco... obviously only the best! Link to comment https://www.sau.com.au/forums/topic/346166-info-c34-after-tunning-infosouth-aus-and-altessa-fluid-info-ect/#findComment-5574726 Share on other sites More sharing options...
bubba Posted December 1, 2010 Share Posted December 1, 2010 Series 2 (Neo engines) ECU's are NIStunable, see www.nistune.com Link to comment https://www.sau.com.au/forums/topic/346166-info-c34-after-tunning-infosouth-aus-and-altessa-fluid-info-ect/#findComment-5574754 Share on other sites More sharing options...
Sawers_88 Posted December 1, 2010 Author Share Posted December 1, 2010 (edited) chef do u know what the nissan specs are? i work for nissan but we have little info (ie fluid recommendations) on imports ect. also whats the go with nistunes just add on to standard ecu or completely diff unit? Edited December 1, 2010 by Sawers_88 Link to comment https://www.sau.com.au/forums/topic/346166-info-c34-after-tunning-infosouth-aus-and-altessa-fluid-info-ect/#findComment-5574806 Share on other sites More sharing options...
bubba Posted December 1, 2010 Share Posted December 1, 2010 It's a daughter board that is soldered in to the ECU that allows you to tune real time via the consult port. Link to comment https://www.sau.com.au/forums/topic/346166-info-c34-after-tunning-infosouth-aus-and-altessa-fluid-info-ect/#findComment-5574896 Share on other sites More sharing options...
rd-runr Posted December 1, 2010 Share Posted December 1, 2010 Series 1 stagea ecu not mappable and won't run nistune. Boostworx Cavaan for tuning. Ok first up- Spec's for the altessa fluid? sitting on the low mark atm wondering what fluid to actaully top it up with. using gen nissan fluids so is it a matic d or matic j fluid? or is it just a general ATF fluid?Next up- Has anyone had any experience with tunning/dyno'ing rs4's? just after general bit of info on tunning places in adelaide. Decent places to go with 4wd dynos. Also are stagea ecus remappable? Link to comment https://www.sau.com.au/forums/topic/346166-info-c34-after-tunning-infosouth-aus-and-altessa-fluid-info-ect/#findComment-5575239 Share on other sites More sharing options...
chef_stagea Posted December 1, 2010 Share Posted December 1, 2010 Fluids = transmax z for everything but coolant= decent stuff nulon do great stuff, diff oil, gearbox and engine oil r all preferance, Sparkplugs are bcpres?? I think 0.8mm Nisstune only on series 2, go to garage 7 only for this. Tuning only go to turbo tune. Dealt with well over 20 stags i personly know of, 2 and 4wd, hot and stock! If u need anything eles mate flick me a txt 0400099986... Seems clayton wont b getting my buisness Series 1 stagea ecu not mappable and won't run nistune.Boostworx Cavaan for tuning. Link to comment https://www.sau.com.au/forums/topic/346166-info-c34-after-tunning-infosouth-aus-and-altessa-fluid-info-ect/#findComment-5575259 Share on other sites More sharing options...
Sawers_88 Posted December 1, 2010 Author Share Posted December 1, 2010 ah k cheers mate. not sure what direction im gonna go with the stag yet. either keep it as it is as a stockish daily or do bitta work ie cooler, fuel pump, bit of boost and tune or possibly sell it. Link to comment https://www.sau.com.au/forums/topic/346166-info-c34-after-tunning-infosouth-aus-and-altessa-fluid-info-ect/#findComment-5575317 Share on other sites More sharing options...
