Anyone have any ideas why my car misfires at two times:
1) cruising from 70-100 or so, then throw it back to 3rd, and floor it, i get a pause, about 3 small pops, and it takes off like a rocket. This is not so bad, just a bit annoying.
2) Taking a slow corner, or almost stop at lights or something, 2nd gear, low revs, if i give it too much too soon, i get almost full boost, but the revs wont pick up, it feels as if its choking, sometimes it misfires. I have to back off, let the pressure blow of, pick up the revs a bit, then floor it.
I have a SAFC, i dont think its fuel. The car has done this for as long as ive had it, im just getting sick of it.
Someone suggested spark, and pulling the plugs out, cleaning and gapping to 0.8 has made it a bit better. I have NGK plugs, any suggestions, new plugs (what brand), or other causes?
https://www.sau.com.au/forums/topic/3470-misfiring/
It sounds like not enuf spark is getting through for one reason or another. Could be coil packs playing up, heres a cleaning technique I read in HPI (or was it Zoom?):
- clean the rubber boot on the coil pack with degreaser. Dirt and grime makes it easier for spark to find ground through the insulating boot rather than the spark plug
- spray the rubber boot with a silicon based spray to further insalate it. (I used WD40)
If none of the coil packs are terminaly fautly, hopefully that should sort it out.
NGK plugs are safest to use with our cars, they come factory standard on all jap cars I've seen. Whats the service interval for NGK coppers, 10-20k km? Probably best to replace them if you don't know when they were last changed.
https://www.sau.com.au/forums/topic/3470-misfiring/#findComment-58078
yep, they are about 6000 k's old. There was some oil around the coil packs, which looked like it was clean, and put there intentionally, ill try WD40 or something. The coil packs actually look quite new.
I am going to get those expensive plugs, to see if it makes a difference, seings its only under high load, that it misses.
https://www.sau.com.au/forums/topic/3470-misfiring/#findComment-58152
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
