I had a thought tonight which is dangerous. :)
I ripped out the wastegate actuator & drilled a couple of 9mm holes next to the origional mounting holes to allow the wastegate actuator to be pulled back and tightened up if you like.
What I'm hoping to do is restrict the full open movement so it helps prevent boost drop in the higher RPM's.
I was able to get in a few fiddles before it went dark tonight.
I'm not using a boost controller.
First tweak showed around 14psi being held up to around 5500rpm where boost dropped by 1psi.
Second tweak bumped boost up to around 16-17psi where up around 5000rpm I hit the fuel cut & heard a little bit of pinging due to boost rising slightly more. Hence the wastegate wasn't able to open enough to control boost.
I tweaked it back a little and moved it too much.
I tweaked again and got it up to around 14.5psi with boost only dropping 1psi over 5500rpm.
Previously it wouldn't matter where I set boost to with a bleeder or EBC in manual mode, it would always drop back to 12-12.5psi over 5500rpm.
Tweak a little more and bring the top end boost up to around 15-16psi.
Its a little bodgy but hey.. its free. :)
Should be interesting to see if it pans out tomorrow. :)
Be carefull playing with this bodgy mod people as I've soon got another motor to play with so i'm not to fussed about damaging this sucker.
I'm trying to get it to hold boost for the next dyno day.
Then compare it to the new motor.
https://www.sau.com.au/forums/topic/34787-my-bodgy-wastegate-actuator-mod/
  • Replies 43
It appears with a bleeder it will only hold roughly 1.5-2psi more than the actuator is rated at.
With a EBC in Auto mode with fuzzy logic it will hold what ever boost thrown at it, my Blitz SBC-iD had no problems holding 15-16psi up top.
Looks like it.. Getting ready for the dyno day.
I fiddled with the actuator on the way home from work this afternoon with excellent results. :D
It took 2 tweaks to get it holding boost up top like I wanted it to.
The final tweak came up on to 15psi pretty hard then in third & fourth slowly creeps to 16psi.
I've tweaked the bleeder a little to bring it straight up on to 16psi and now it holds perfectly flat from 3500rpm (16psi) to 7000rpm. No point reving to 7500rpm.
Defiantely screams up top now. Huge difference in second as previously it would start to die off after 5500rpm and feel like it was just reving, now you can hear the turbo really pshhhhhing :D while you feel that rb20 top end scream.
hey, i also had an in line restrictor boost control, and even bleed control. but i thought the cheapest and best option was that same idea, i drilled a couple of holes and routed in through to the original holes, i am happier with the result, pity i had wasted money on the other boost mods, as this ones cheaper! like no cost!, also i have been playing around with the use of springs onto the wastgate lever, simple way of making the wastgate change its characteristics, just use a heavier spring for more boost.
the only thing i noticed is that if reving 3rd,4th,or 5th when lower in the rev range, the boost will go higher than your optimum gear reving up, but i guess you should always be in the best gear of acceleration if you want to accelerate, even in town driving. just alot more foot control need to be used.
I personally would love an electronicly controlled system, were boost was held perfectly at pre selected levels. but at the price of nudda for the above setup i keeping my money for better value mods.
ps i keep my boost max at 14 but mostly around 12, reliable factor.
Dayna
Dayna,
EBC's arn't all they are cracked up to be. Well mine wasn't as good as I expected it to be. To be honest it was a little dumb and required fiddling with every now and again.
Even when the ebc was in auto mode (dial in the psi you want and it does the rest) & driving up a hill in say fourth gear with lowish rev's boost will climb and spike to 17-18psi where the safety ebc thing would dump the wastegate open. + in auto mode the boost wouldn't hit as hard.
When the EBC was in manual mode which works on a percentage of maximum boost it wouldn't spike up hills etc but it also wouldn't hold boost up top. In manual mode boost would hit nice and hard.
I was going to fiddle with the heavier spring on the welded wastegate but this seems to do the job nicely.
Up hills etc mine doesn't spike high if anything it tends to come up to 1psi under what it runs when at 7000rpm.
RedlineGTR,
Have you tried a RB20DET turbo actuator. They hold 10-11psi standard.
guys
i have also looked into this, although i havent tried it, if you think about it, if you in effect shorten the amount of travel on the actuator the effect will be somewhat like an oxy torch where you have hot gasses comming out of a small(er than usual) hole, in this case the wastegate, and burning the wastegate, which in time would become burn on the edge in the same way metal is cut using an oxy cutting flame.
so be carefull...
but like i said this is all only in theroy, it may be different when put to practice, as most things are
guys
so be carefull...
No it wont burn the little flap. It would melt the exhaust housing too if it was that hot. Even with the actuator in its standard position, the wastegate never really "fully" opens.
Bending the actuator arm is another way of doing it. Just dont break the arm. :D
Have you thought about cutting the end off totally, tapping a thread onto the remaining part, and somehow making a "socket" threaded rod with a mounting hole in it? This would effectively turn it into an adjustable actuator the same as the HKS ones.
I've thought of this in the past and think it would be pretty simple to do - if i could be stuffed
Hmmm, interesting, i might have to try something too!!
I can watch my boost drop from 12psi to 10psi as revs rise, damn i hate that
Since my last dyno run, and I watch it drop from 12psi to 9.5psi as the revs got up high, I've been pondering the same thing.
Any idea what an HKS adjustable actuator costs??
I'm pretty sure it would be the spring tension, it just can't hold the flap closed as exhaust gases increase and speed up :)
I'd be keen to hear from someone that has done the 'R32 actuator on a R33 turbo' mod :D
J
New I think around $150-200. Mine cost $75 second hand. If you see one for under $100, I say grab it. Definitely worth the bucks if you're dropping boost.
wouldn't the boost drop jhust be due to the stock turbo not being able to flow enough at high revs?
That could also be a factory in it too :D But I think at the relativly low boost, I'd say the actuator is the main reason.
Thanks JimX - that's a good price and I'll be keeping an eye out for one.
J
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
