what is a standard rb20det spring rated at? 10psi?
i'm guessing that the spring that i use would be relatively stiff?, i suppose its just best if i fiddle with some springs from the local shop...
what form of measurement are springs rated on, whats equivalent to 3-5psi.
cheers
  • Replies 43
  • 4 weeks later...
SydneyKid does the RB20DET bolt straight onto the standard mounting brackets, and were do I get one?
Yes and I took mine off the RB20DET turbo I had lying around not being used when we put the hi flowed RB25DET turbo on it. The other one came from GCG, they also had it lying around as no one seemed to want it, everyone wanted the nice shiny RB25DET ones. Maybe I should have kept my mouth shut, now they are gunna get hard to find "lying around".
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
