Wanting to trade my 1993 Skyline r33 gtst for a non turbo r34 ! I am willing to add up to 2000 cash and i live in sydney nsw
If anyone is willing please contact 0433222006 asap ! :D
Oh and if you want to buy my car i guess $11 000
https://www.sau.com.au/forums/topic/347929-anyone-have-na-34/
If your interested in an N/A R33 I've got one that'll get you by until your off your P Plates and has all the mods you'd need except a turbo atm...
http://www.skylinesaustralia.com/forums/topic/335985-1995-r33-gts-4/
