2007 Subaru Impreza R 2.0 Rego: YEV-34R. 68,000 KM's. 5 Speed Manual. Location: Canberra.
This was my wifes car and was one of last vehicles made of this particular model before Subaru switched to the more inferior and cheaper Hatchback model. Unlike the Impreza i version, the Impreza R has the more powerful DOHC 118Kw 2.0L engine. The Impreza R also has the better suspension and larger brake packages (close to that of the WRX) which makes for a much more comfortable, fun and safer drive. It also has the 16 Inch alloy wheels and the Kenwood factory audio system (only available in the later models) which includes a factory Subwoofer, front 2 way splits and iPod connectivity. It also has the usual extras like cruise control, A/C and power windows/mirrors.
Car Details:
1 female owner since new, always garaged and regularly serviced and maintained. It has always been run on 98ron fuel and will get 500kms per tank in the city and much much more on the highway. It is mechanically in A1 condition and was serviced a couple of weeks ago. It runs like new and everything is in perfect working order with no problems what so ever. A 2 1/4 inch cat-back exhaust has been fitted for better fuel economy, better looks and for a quite yet sporty exhaust note (not your typical blaring WRX sound). The tyres are all in good condition. The car is extremely reliable and wont disappoint.
$19,500 ONO.
A roadworthy certificate will be supplied with the car upon its sale (certificate will be attained when a deposit is taken to ensure it doesnt expire). Any inspections/test drives welcome. No swaps or low ball offers please. Selling for financial reasons...
Contact Luke on 0438 481 354 or PM. Cheers...
post-17810-0-93547500-1293072119_thumb.jpgpost-17810-0-44829900-1293072104_thumb.jpgpost-17810-0-16870500-1293072190_thumb.jpgpost-17810-0-20591700-1293072127_thumb.jpgpost-17810-0-72252500-1293072160_thumb.jpgpost-17810-0-99050200-1293072152_thumb.jpgpost-17810-0-89054600-1293072223_thumb.jpgpost-17810-0-93378800-1293072255_thumb.jpgpost-17810-0-75284700-1293072278_thumb.jpgpost-17810-0-77766700-1293072290_thumb.jpg
$18,500.
I've been driving this car the past couple of months and I actually like it! No I'm not getting soft in my old age! Its pretty much a WRX without a turbo and higher springs. That's it! A great little car around town...
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
