91 S13 Silvia Ks Sr20Det 5Sp Lsd Rear Coilovers, Metal Head Gasket
91 silvia ks model sr20det
200ks
5sp
lsd
body is a bit dinged up due to hitting small kangaroo but has never hit anything hard and doesnt have any bog around it
coilovers in rear lowered springs and shocks in front solid as
sr20det with metal headgasket and arp rod bolts very tough engine with good compression in the process of removing blown original turbo and putting on s15 t28bb turbo,
dont have time or energy anymore to complete, the manifold turbo and dump are all dissconnected just need to squeeze it out and bolt on new turbo and o2 sensor, all bolts are bagged and tagged also took pictures beforehand so i knew where everything had to go. If i can talk one of my mates into bolting turbo and sensor on i will just raise price as it will be able to be test driven then.
new o2 sensor on its way from usa will be included in sale price
17inch rims with potenza g3 tyres all borderline tread
exedy heavy duty clutch put in 5000ks ago in great nick new throw out bearing put in too
s14 drivers seat
average cd player and speakers
3inch cat back exhaust
trust copy baffled sump
alloy pulleys have one for the fan too.
thermo fan (needs wiring to temp switch but works great)
big front mount
spare sr20 in need of rebuild dropped a valve comes with intake manifold, throttle body, stock clutch and flywheel, alternator, full loom etc (no injectors or turbo)
offers around $4200 for everything mentioned above
or $3600 without s15 turbo and o2 sensor
or $3200 without wheels and tyres bring your own, no s15 turbo and o2 sensor
or $3000 without wheels and tyres bring your own, no s15 turbo and o2 sensor and no spare sr20 and parts
can guarantee engine and new turbo are in great condition, turbo came of my mates 2002 spec r gt with 50000ks with service records so its like new and i drove car multiple times with blown turbo and is a lot quicker than my soarer and ran well.
check out the rb20det pintara in my other items can do a package deal, need to pay for uni.
sorry pics are too big for sd can email them or go to boost link
http://www.boostcruising.com/forums/index....howtopic=677564
0413663094
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
