I am currently putting up for sale my Series 1 R33 4 dr GTS25T. The car is in very good condition except for a cracked grill and a little rust on the front door. There is no rust anywhere else on the car. For a standard car is still quick.
Car - Series 1 R33 GTS25T
Year - 1993
Odomteter - 185,xxx kms
Rego - I will be putting fresh rego on car today so it will have 3 months new rego
Colour - Gun metal grey
Kit - Standard GTST with a GTR spoiler
Motor - RB25 DET
Gearbox - Electronic 4spd Auto
Diff - LSD
Brakes - GTST brakes with very chunky pads left
Suspension - Has been lowered no coilovers etc
Rims - R34 GTT's sprayed grey with near new 225/45 on front and good 235/45s on rear
Interior - All clean GTST no rips etc
Sound Sys - Pioneer USB head deck worth a lot, Sony front splits and tweeters in front and Pioneer 2 ways up rear. All sub wiring has been connected and taped for now but no sub and amp in car
This car runs stock boost and has not been boosted up. Runs the little side mount cooler still. I have no trouble with the cops at all. Runs perfect, no mechanical issues with it at all. I am only selling it due to needing a wagon. I will not trade as I already have a car in mind that I am after.
Im after $9000 or best offer.
I am contactable on 0420 438 536 or email [email protected]
I dont currently have any pics of interior or engine bay but if they are wanted dont hesitate to ask and I will get some. They are all stock anyways.
https://www.sau.com.au/forums/topic/350042-r33-4dr-gts25t-in-sa/
Will consider trade for Holden or Ford wagon as that is what I am after at the moment. Will consider a swap for a Stagea even if non turbo as long as its clean. No shitty VN or VP wagons. After something like a VX or VY or BA wagon. Wagon has to be clean. If have a car of lesser value will want cash on top. Cheers.
BUMP.... Do not need trades anymore. Will lower price to $8000. Just rego'd. Good car for someone who wants a turbo without the hassles of worrying about a defect as all stock. And can be used as a family car as is 4 door and has two brackets for two baby seats if required.
Contact info in first post.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
