93 r32gtst 176xxx , xtreme hd clutch (less then 50km old) ,fmic,vertex kit (sides needed to be installed and whole kit painted) 17 inch mags (needs rear tyres), bov,bleed valve set at 13 psi,
3 1/2 straight thru exhuast ( needs a tip as i had to cut the old drift pipes of to install the vertex rear)Shaved rear boot lock (in primer), air pod.. the interior is a little worn.. it just really needs to have a few things put back together and painted to put back on the road..The motor/ driveline runs perfectly and was verry reliable for me
As is where is.. no rwc or rego
$4500 FIRM
Logan Village QLD
post-51560-0-88563300-1295664395_thumb.jpgpost-51560-0-32308800-1295664428_thumb.jpgpost-51560-0-47216900-1295664475_thumb.jpgpost-51560-0-54668100-1295664535_thumb.jpgpost-51560-0-32452800-1295664560_thumb.jpgpost-51560-0-89766200-1295664593_thumb.jpgpost-51560-0-16106900-1295664637_thumb.jpgpost-51560-0-74163800-1295664662_thumb.jpgpost-51560-0-07696000-1295664740_thumb.jpgpost-51560-0-64969800-1295664770_thumb.jpgpost-51560-0-73033200-1295664815_thumb.jpgpost-51560-0-28255500-1295664841_thumb.jpg
Edited by rolzy32
https://www.sau.com.au/forums/topic/351317-93-r32gtst/
  • 1 month later...
it hasn't taken close to 4 days to realise, I allready realise your a wanker now.. Ive already had over 5 offers to come take it for 3k which i have turned down.. If you don't like my price then don't post in my topic. :) have a nice day finding a 32 for 2.5k
https://www.sau.com.au/forums/topic/351317-93-r32gtst/#findComment-5704373
no need for insults..
I was merely saying that you were wrong about your price and I am right.
and you are also lieing about being offered $3K by 5 people.
I mean who the fark would turn down an offer $500 less than asking price for a car which needs about $3K worth of work to be road worthy?
also I didn't see that you were from Logan.
My revised offer is $2300
Edited by GTST
https://www.sau.com.au/forums/topic/351317-93-r32gtst/#findComment-5704383
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
