Great condition z32 with large 200m airfilter orange in color. Comes with adaptor to fit z33 and a 3-4" silicome reducer. Could throw in 4" stainless polished intake pipe aswell for an extra $50.
Looking for $250 posted or 300 with intake pipe.
DEFI White Face Boost Gauge, Oil Temp, Oil Pressure, Water Temp and Controller unit with one link cable.
asking $650
nothing wrong with these but i dont have sensors an im going a different route with guages.
Volk/Rays Engineering TE37 Rims
18x8.5 +30 front
18x9.5 +40 rear
With 15mm bolt on spacers all round
Swap for 18" Work XT'7s only, or R34gtr rims plus cash my way. Will negotiate on either of these only!
would also consider injectors and power fc to suit r32 rb26
or cash, offers around high 2k (thinking 2800ish)
cheers
0467505670
z32 gone
wheels and guages still avail
now ad clearly states that i dont have sensors, have had easy 10 people in contact and cracking shits with me cause i dont have sensors, GTFO dont waste my time, 4guages with link and sensers go for $1000 plus, sensors are avail from pro speed racing in nsw or from jesse streeter in japan at a very good price, remember tht my guages are brand new never used and that once purchased sensers you would be still under 1k!
i will also swap wheels/guages for a daily car.
cheers
Port macquarie. Dont mind meeting somewhere if desperate
Text me or call 0467505670
Good ole Port Mac! I was up there recently, having a great time. I'm west of Sydney.
I'll ring or text later in the week, if they're still around.
desperate for sale here. really need these guages gone so i can free up some cash
dont start new job for another week and just had the couple we live with pack there shit and move out while we were away camping
also have a cusco front swaybar for sale, rather large 30+mm in diamater from an s13 silvia. fits with rb20det but not r26. cant comment on 25
$100 plus postage or pickup.
cheers
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
