The engine has not been used since being built, so everything is still in brand new condition (you can still see the assembly lube).
The engine was built through Sam Cornell, aka Dr Drift.
mild port and polish
HKS step 3 head kit:
HKS retainers
HKS inner and outer valve springs
HKS valve stem seals
HKS solid lifters
HKS black coated rocker arms
HKS adjustable cam gears
HKS 264 inlet camshaft
HKS 272 exhaust camshaft
rocker arm stoppers
custom shaved rocker cover
2.2L block:
machined and sleeved block
darton sleeves
HKS pistons
HKS rods
HKS crank
trust/greddy over-sized sump
greddy pulley kit and blue gates belts
new oil pump
new water pump
new timing chain
new timing chain tensioner
build to rev to 9,000rpm
$11,500.
no low ballers.
engine is located in perth, but can be shipped anywhere.
pictures will be sent to those who are genuinely interested, so please pm if you are.
https://www.sau.com.au/forums/topic/354770-hks-sr22det/
