Hey guys selling my s13 auto sr20 needs a little love to make it a super cheap nice car to run
paint needs a lil touch up but looks really good and exhust leak other then that nice little car
no much to take this car to bigger and better things
$2000
As is
Queensland brisbane
pick up only
hit me up pm or 0406635400
Edited by navanskyline
https://www.sau.com.au/forums/topic/355690-s13-auto-sr20-cheap/
