for the price of what you wanna do, you could probably get an R32 GT-R perhaps even an R33 GT-R.
N.B. R32 GTS-t is rear wheel drive (1 diff) R34 GT-R is 4WD, So 3 diffs (front, centre and rear)... You would have to replace the whole drive line since they are also different lengths and i'm certain wheel base... I'm not sure if you can convert a GT-R to RWD only (probably can, but cost the moon), plus what does an RB326DETT NEO go for, $8k++ ???
My 2c
https://www.sau.com.au/forums/topic/35599-motor-question/#findComment-711138
In that case yes it will fit. Yoy'd want to swap the GTR gearbox for an RB25DET box as the GTR includes a centre diff in the gearbox. Also need to swap to an RB25DET sump and get rid of the front diff. Lots of work and money
https://www.sau.com.au/forums/topic/35599-motor-question/#findComment-711331
