Cleaning up my room, guys. Just let me know if you need some stuffs, cheers.
If you arent happy with the price, just text me or email me, I'll adjust it accordingly.
1. Volk Rays TE37 in bronze 18x9.5 +22 all around. Looking to swap with TE37SL in the same spec,
or if someone wants to buy it outright, you can get them for $2900.
Can come with 265/35/18 Michelin Pilot sport for $3200.
Or you can buy just the tyres alone for $400.
2. Work Emotion 11R FT. New product line of Work Wheels for 2011. Retailed for $2360 for a set.
Here is the link click here
WORK Wheels has introduced a new version of Emotion 11R, EMOTION 11R-FT. This new wheel utilizes WORK Flowforming Technology.
	The key benefit for flow forming is the ability to reduce the barrel thickness, thus reducing the weight of the wheel without compromising the strength of the rim barrel. The 11R-FT is an excellent choice for motorsports racing use.
	WORK flow forming wheels start with low-pressure cast construction, whereas some of our competitors use lower quality gravity casting.
	Low-pressure cast construction has a denser material property over gravity cast wheels, thus allowing a greater strength advantage over gravity cast with flow-forming barrel.
Specs are 18x9.5 +25. Chasing $1600
Can come with tyres, just pm or text me.
From now on I'll keep telling myself not to buy a set of rims that is too aggressive, as the evo is my daily. lol.
these were brand new, no gutter rash, etc only paint flakes off.
Concave
Rim 1
Rim2
Rim 3
Rim 4
3. Mitsubishi/Ralliart Din Gauges, perfect condition, comes with all those wires. $375
All items are located in Melbourne, pick up preferred but interstate courier is available at buyer's costs.
Contact me:
text to 0433552745 - Gerald
email to [email protected]
pm me, or just simply reply,
Thanks
Edited by gerz
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
